Nice looking bike, but you do have a really strange bar setup. Maybe you want it like that for a particular reason, which is fine, but I think it could be too extreme to be useful. It look like you've set the levers in that position so that you can brake from the drops without having a long reach to the brake levers, but in doing so you've totally eliminated the posibility to ride on the hoods.
As a general starting point, the actual brake lever should be more or less vertical (it depends on the make, model, personal preference, etc). This gives a resonable position for riding on the hoods, and the lever can be reached from there, from the drops, or quickly from the centre of the bar if you're riding on the tops. In the position you have them in, I can't see you reaching the brakes quickly from the tops, which could cause some potentially dangerous delays in braking when riding on the tops.
If you can't reach the levers from the drops when they're in a more conventional position, then I would try changing bars to a more classic bend, which will leave your hands much closer to the levers when in the drops.
If you only ever ride on the drops, then I would think about lowering the bars by changing the stem, and using the tops and hoods all the time. You'll have more hand positions that way, and will probably be more comfortable.
As I said, maybe you have the bars that way for a particular reason, in which case just ignore all that I just said...
