Wolf Tooth has a new modular multi-tool that covers all manner of basic road and trailside repairs and then some. The 8-Bit System builds on the success of the company's 8-Bit Pack Pliers with additional functionality to get riders out of most jams. Read on for details from Wolf Tooth.
The 8-Bit Chainbreaker + Utility Knife Multi-Tool and the 8-Bit Tire Lever + Rim Dent Remover Multi-Tool join the 8-Bit PackPliers to complete the system.
Hand Finger Automotive tire Bumper Thumb
The three neatly nest together using magnets and clever machining for compact storage. The 8-Bit Chainbreaker + Utility Knife Multi-Tool has three functions. It has a chain breaker on one end and a retractable utility blade on the other.
Hand Automotive tire Gesture Finger Thumb
The chain tool is operated by an included 3mm hex L key that doubles as a tire plug inserter. A machined slot fits the L key and converts the entire multi-tool into a tire plug inserter, with the forked end of the L key extending outward.
Tire Hand Bicycle Wheel Crankset
The handles of this multi-tool slide open to provide storage for tire plug inserts, a valve core, and a spare mini utility blade.
Bicycle Wheel Tire Bicycles--Equipment and supplies Bicycle wheel rim
The 8-Bit Tire Lever + Rim Dent Remover Multi-Tool has two functions. A slender, ergonomic plastic tire lever is on one end opposite of a machined aluminum rim dent remover. The tire lever will work with all tubed and tubeless tires, while the rim dent remover is compatible with all metal rims.
Hand Bicycle Finger Bicycle part Bicycle frame
The 8-Bit System takes its name from the 8-Bit Pack Pliers, as the two new multi-tools have the same silhouette and nest neatly together. The 8-Bit Pack Pliers Multi-Tool has 17 functions. On one end of the multi-tool, an 8mm swivel head serves as a driver for the bits that are stored inside: flat head #3.5 and phillips #2 screwdriver bits; 2, 2.5, 3, 4, 5, and 6mm hex; and T10 and T25 Torx-compatible bits.
Hand Automotive tire Finger Wood Asphalt
A spoke wrench and valve core wrench are stored on the back and a rasp is on the inside of the upper handle for clearing sealant from valve stems. On the other end of the multi-tool, pliers for master link installation/removal and tightening/loosening of valve stem nuts.
Tire Hand Bicycle tire Bicycle frame Wheel
These tools were designed, engineered, and machined at Wolf Tooth in Minnesota from 7075-T6 aluminum. These new multi-tools can be purchased individually or as a complete 8-Bit Kit One set that includes all three.
  • 8-Bit Kit One: $139.95 USD
  • 8-Bit Pack Pliers: $69.95
  • 8-Bit Chainbreaker + Utility Knife: $69.95
  • 8-Bit Tire Lever + Rim Dent Remover: $19.95
The 8-Bit System is now available on WolfToothComponents.com and with all bike shops that stock Wolf Tooth products.
