1 - 10 of 10 Posts
Hey Folks,
I'm just getting back into riding after a 15 year layoff. I picked up a late 90's Mondonico with 8-speed Campy Record. Love the way the bike rides. Much plusher than the Klein Qunatum Pro I road in the 90's. My question is this.....if I were going to upgrade the gruppo, what should I consider? Only Campy? And if so which group? Or should I even consider Shimanoi or Sram? You opinions would be welcome.
Thanks - Howard
Decrepit Member
Man, I'd leave it exactly like it is. The Campy Record 8-speed group with the Ergo shifters is perfect for that bike, IMHO.
If you absolutely have to upgrade it, I'd go with 11-s Record or Chorus Carbon with a compact double crank, but the carbon won't look as good as what you've got.
Again, just MHO.
Off the back
You scored with a real beauty there - don't change a thing other than using good tires, which they make much better nowadays.
Your biggest handicap will be lugging (lil' pun there) around the extra five pounds compared to your buddies on the latest Ti or CF rides. That could hurt you in the climbs, but not too badly in the flats.
Agree with everyone. You don't mention any particular problems. Check out chain & cassette wear. The cassettes are still around if you need to replace. 9-speed chains work fine if not better than the original.
When you've been riding a year or so, and think you deserve it, get a modern bike, but don't change anything on this one.
I love Campagnolo 8 speed. The only recommendation I would have, is if the gearing is too high for you, go to a compact crank. Other than that, ride it until it breaks, then see if it can be repaired inexpensively (likely).
Mondonico's are fine bikes. Does yours have Nemo tubing?
1 - 10 of 10 Posts
