1 - 7 of 7 Posts
Well, for a change of pace I took my new GT Cross Bike out for it's maiden voyage today. It was my first time on a cross bike (off road at least) and I must say...I was pleasantly surprised.
The bike did much better off road than expected. I basically went on a 26 mile fire road ride that had a lot of semi-rocky sections in it...and thanks to the really wet spring around here it was very, very muddy as well...so it was broken in correctly :D
In many ways the bike handled much as my MTB does, but was much more efficient. I ran the air pressure higher than what it sounds most do here (60 psi with 35c tires) and felt that it had quite a nice ride at those air pressures and with some of the rocky areas no pinch flats, so I'll probably stick with it for now.
The Panaracer tires held a line really well, cornered much better than expected, especially given the conditions and the brakes still worked very well even in all the mud.
The only thing I didn't like as much was the gearing. The front is geared a bit high for general XC usage...but other than that...it was fine.
My first experience with SRAM Rival is mixed...but not bad. I think I need to fine tune it, but once dialed in, I think it will work great.
Overall...very impressed with the cross bike and I can't wait to use it for Short Track XC and for the Cross season to get here...My wife however, having just cleaned the house and me coming in super muddy isn't :blush2:
Number 2 on the course.
Curious: How much do you weigh? 60 PSI is high but rider weight is a big factor. It might not matter if you are already satisfied with 60, but I find that lower is better (on dirt), so the lower you can go without worrying about flats the better.
Not Banned
he's a Clydesdale
like me. At our weight running any lower than 55 is pinch-flat-athon, I used to run 60-65 on rough courses andstill flatted every once in awhile. Oh and at those pressures the tires grip like sh!t, so you don't pinch flat, but you slide.
just another reason I made the leap
As per the signature line on my posts...:D ...I'm low 190's for weight. I don't know that I'd venture much lower with the air pressure. To me it felt like a good balance between traction (of which I had plenty), ride quality and pinch flat resistance.
After today's ride, I just don't see a need to go any lower really....and I really don't want to worry about flats...I hate flats :mad2:
FatTireFred said:
is that bike disc or rim brake?
Rim brake....Tektro canti brakes. Honestly, they surprised me by how much power they had in them even when covered with mud. I think I went through half the pads today, but they worked...and worked well :thumbsup:
When dry they are stong enough to do nose wheelies with, and when muddy provided solid stopping power....which is good enough for me.
Game on, b*tches!
As for the tire pressure; I'm about the same weight as you and in no danger of going much less. I ride my clincher (backup) tires at about 40-45 with no issues. You could probably drop to 50 psi easily. You'll notice an even better ride/traction.
1 - 7 of 7 Posts
