how much difference to my fit would result in a .2 degree reduction in STA, a 1 cm increase in TT length, and corresponding 1cm increase in ST length?
If I'm running a 110 mm stem and have a good fistful of seatpost available out of the frame, will I be able to make this glorious frame I'm looking at fit me nicely? My saddle is also fairly far back on the rails.
I'm desperately close to pulling the trigger because it is such a great deal but I wonder if I should be nervous about the size increase? But shouldn't I be able to replicate my old fit on this bike rather easily? I figure the saddle is in a more natural position, 90-100mm stem, little less seatpost showing, no problem at all... I'm also running about 3 1/2 inches (9cm) of saddle to bar drop, with stem dropped down on steerer with no spacers below it.
It'll be a race bike...thoughts anyone? For all of you, could you all make a +/- one size increase without too many troubles? Will this potentially affect handling/whatnot or will this really not be difficult at all?
I'm 5'8", longer legs but pretty normal overall build, considering this new frame with 54cm ST, 55 cm TT (both c2c), and 73.5 ST angle. My current bike has a 53ish ST, 54cm TT, and I'm not quite sure of the ST angle. It's a pretty stable geo overall.
