1 - 20 of 20 Posts
Sticky Valentine
Would adding 5mm to my cranks make the outside/front of my hips hurt?
Just changed the cranks on my commuter, and I've been having hip issues that I've noticed coming on for about a week or so, not too long after changing the cranks out.
Also went from a 42x16 to a 46x16, on a single speed and from 165's to 170's. Not sure if either/both of these things could be the problem.
Do you think it could be from changing my cranks and my body is adjusting after riding that bike nearly every day for a year, or is it probably something else.
To help entice an answer, here is a picture from just a couple minutes ago.
joe
Sticky Valentine
Discussion Starter · #2 ·
Notice the extreme righteousness of the beard.
joe
Non non normal
It is like raising your saddle a half centimeter. It may be the culprit.
Sticky Valentine
You know, I was trying to work out the logic in my head, because I assumed that it would have an effect on other parts of my bike set up, but I wasn't sure where to add and where to subtract. I'll try taking the saddle down a short and curly and see if that helps.
joe
Captain Obvious
dude, you had 165's????
aren't you like 7'12"???
i use 175's. you essentially changed your pedaling rotation by 10 mm since it's 5mm per arm. i'd lean more towards the change in gearing tho.
waterproof*
5mm longer crank means lower your saddle 5mm and slide it forward on the rails 5 mm.
and yeah, that could be the cause, since it also means your foot is higher at the top, and your hips are more closed at that point.
Windrider (Stubborn)
A small muscle tear or strain.........multiplied by 90+ rotations per minute, for a couple of hours a day.........yea....that kind of change would do it.
len
Non non normal
Off the top of my head, I don't think you would move the saddle foward a full 5mm. Because of the angles your legs create I think it would be less than 5mm.
waterproof*
if you're following conventional KOPS wisdom, yeah 5mm is what you'd do. KOPS ignores the "back" leg and positions from the "power" leg.
whether that's right or best, I'm open to debate, but it's the usual way.
Jerkhard Sirdribbledick
Hmm, seems like you'd have to take the angle of the seat tube into account. But I actually have no idea.
Sticky Valentine
Discussion Starter · #11 ·
len
Smart arse.
:p
joe
Sticky Valentine
Discussion Starter · #13 ·
El Caballito said:
nice jersey!
Thanks! I love it... it's fairly thick, perfect for cool So. Cal. evenings. And looks good to!
joe
trying to HTFU...
i vote for dropping the seat 5, and then seeing where you land on the bars
to determine how much to adjust the seat fore/aft(prolly not much.)
hip flexor pain is from too closed of included angle made by thigh and torso.
Non non normal
You get a "you are right coupon" from me. But only on this one subject and for today only. :D
Spicy Dumpling
I think that this should photo should give you some starting points on fit.
That's definitely a place to start, I'd just drop the saddle 5 and try it from there. I'm pretty tolerant of a bit of fore/aft adjustment but really sensitive to height. And I think your symptoms would be more indicative of a height problem.
Sticky Valentine
Discussion Starter · #17 ·
Thank gawd it's not a length problem :eek: :eek: :p
joe
Adventure Seeker
It's none of the above. The sad truth is, you're getting older, and you're feeling it. It's just pure coincidence that it happened when you changed your gear.
:p :lol:
your text here
you cahnged a lot of stuff, so it could be a lot of things. it could even come down to a slight change in cleat/pedal setup. adding new cranks, while a small change many people think doesnt matter, can open up a finicky rider to all sorts of problems.
i cant believe nobody said:
"yer seats too high!"
thats what she said.
1 - 20 of 20 Posts
