1 - 9 of 9 Posts
Old enough to know better
Finally back into biking again after a year off and selling my old ride thinking I didnt want to ride anymore. Got bitten by the bug again this spring and ended up getting an 06 Tarmac Comp. Super sweet ride, real smooth and I love the way 10 spd shifts. Only compromise I had to make was they had no 58 cm in stock so I bought the 56 cm (technically a 56.5cm) I am 6 ft tall, and have average length arms legs & torso. By that I mean I don't have any one part of my body freakishly longer or shorter. The one real fit issue I ve been fighting has been pain in my elbows after say a 40 mile ride. I incur this pain while riding in the drops, it does not hurt while I ride in the drop but when I move out of the drops and bend my elbows. I do ride with my elbows bent so I know this pain is not from straight arms. Is it possible I need a longer stem to lengthen my reach? Any input is welcome and if you need any more info feel free to ask.
TIA
Relax
Since you didn't provide any information about stem length or your relative torso/leg length, it's hard to guess on your fit. However, the most likely issue is that you are not used to riding, and you need to move your hands/arms more so as to not ride for a long time in one position. Many people experience this every spring as they get back on the bike, and IME it is aggravated by cold weather.
I was hoping you would reply Kerry as you seem to have such a wide base of knowledge on everything cycling. My stem length I believe is 110mm. I had a Giant TCR Comp in size L and over the exact same ride route I never once felt any kind of pain in my arms or elbow region. I know solid measurements should be provided for torso, arm & leg length but I do not have that info readily avail. I do feel when I m riding I could stretch out a bit more, but that being said I dont feel caged into the controls. Several times on my last ride I stopped, got off the bike and did shoulder and neck rolls to loosen everything up thinking I was clutching too tight. I have experianced no shoulder or hand pain, and very mild neck pain which I attribute to the adjustment of a road machine again nothing I did not experiance before. I hope this may provide you with some additional info that may help myself a bit more, or that someone with similar problems may chim in.
I sympathize with you, Deastin. I'm 58 years old, and have some arthritis in my elbows. There is no chronic pain, but I can't straighten or bend my elbows all the way. Can you touch your right shoulder with your right hand, or left w/left? Does your elbow straighten out all the way. Is one better than the other? I have 4 road bikes. The cheapest, a Trek Pilot 2.1 causes the least pain when riding and is the most upright. Next is a Bianchi Virata, a super traditional steel frame with modern components. It's also pretty upright. Next is a 2008 Cervelo RS which has the same upright position as the Pilot, but causes quite a bit of pain on longer rides. I attribute it so far to the longer, lower rise stem (110 x +7°). I may have to raise the front of the saddle a touch and install a shorter higher rise stem. These worked for me on the 4th bike, a Bianchi 928 Reparto Corse, which cause me excruciating pain on long rides, but was alleviated by taking the above steps, in addition to fine-tuning it on the trainer during the off-season. Taking an aspirin before a ride also helps, but is not for everyone.
I ride in perfect comfort on my hybrid, sitting totally upright, but then all weight is on the butt, and that gets uncomfortable in the long run!
I just hope you get some helpful advice. Without biking, life would be MUCH less interesting and fun, and health good health harder to attain, wouldn't you agree?
Third Coast Colnago
The thread may be 3 years old, but the subject is still helpful to people. It's not like a three year old "they don't wave at me" thread was bumped. This is a frustrating pain for people because most doctors don't know why it's happening..
I struggled with this last summer and did/do move my hands around so this subject piques my interest. The search function is a tool.
cmg said:
i opened this thread because of the title. elbow pain is common among cyclist. wonder if deaston is still riding.
Yea, it's old but not outdated.
I have elbow pain - broke both elbows (radial heads) about 25 years ago. Generally painless, but limits my range of motion - can't straighten out completely. What tends to get them hurting is if I put longitudinal pressure on the elbow joint, like supporting body weight while cycling. Also pretty sensitive to general arm position, and that is a reason that road bikes are 1000 X more comfortable than any mountain bike set up I've ever tried. More hand positions, and more natural hand positions which stress inflexible joints less.
I tend to be very figitey on my bike, changing positions a lot, which helps a lot. People who have joint problems might not only have to mess with fit, but also accept the fact they can't hold positions as long or consistently as others.
Discussion Starter · #9 ·
I am in fact still here & still riding. The elbow pain went away after picking up a longer stem and moving my saddle back to give a longer reach. I felt alot more relaxed once I got stretched a bit more, but still keeping some bend in my arms.
YRMV
1 - 9 of 9 Posts
