1 - 6 of 6 Posts
A few days ago I was driving right around dusk and passed three cyclists going the other way, all of whom had flashing white headlights. They weren't annoying, just very noticeable.
I have an old set of headlights with a separate battery pack that I used to use when I rode before dawn. They were so good that cars coming towards me would actually dim their brights as they approached, but I can't get up that early anymore. Nowadays, if I'm going to be riding around dusk, I have a six LED light that I use on the front, mainly to be seen, not so I can see. After seeing these flashing headlights, I thought this might increase my chances of staying alive on the road.
Does anybody have any experience with these, and does anyone know if they are legal?
Knives, Guns, and Booze
Yep. Get yerself a 555 timer chip (the Texas Instruments TLC555CP is a common one and comes in a DIP package), a PFET (I use Fairchild NDP6020P units in my flashers), a common DIP switch (SPST is fine), some 18 gauge insulated multi-strand copper wire, two 6.8KOhm resistors (1/4 watt are fine), and a 10µF capacitor (a 25V rated electrolytic works well). Pop the components together onto a blank circuit board (or you can just solder the components together), and you have a current-regulated 555 timer flasher circuit. If you want the flash rate to be higher, then change the 6.8KOhm resistors for some of a lower value (4.7KOhm, 3.6KOhm, 2.2KOhm, etc.), or if you want the flash rate to be less frequent, then use a higher value (such as 5.6KOhm, 6.2KOhm, etc.). If you need a circuit then search teh Googelz for some 555 timer IC LED flashing circuits.
In winter, when my commute home is in the dark,I use a small light mounted on my helmet, and keep it in flashing mode. I can point it in the direction of vehicles that are a particular hazard, especially cars entering from side streets on the right. I think it helps a lot. I have a steady light on the handlebar.
About a month ago, I started using a blinking led on the front and a PB superflash on the rear during daylight hours. It seems to have reduced the number of times someone pulls out in front of me or passes too closely.
So. Calif.
There is no question that flashing or rapidly changing lights are more readily perceived by the human visual system and brain.
Cateye EL-220 is a very bright 6-LED (?) headlight that has a flashing mode ... if anything it's too bright in flashing mode, as it illuminates the roadway with a stroboscopic effect. Probably indicates the EL220 is aimed too low! About $40, IIRC.
Cateye LD150 is a very bright, 5-LED tail light with several flash modes. The mode where individual LEDs flash in a semi-random , back & forth pattern is especially visible. About $15-20, IIRC
The standard included Cateye mounting brackets are prone to slipping, but Cateye makes optional inexpensive brackets that are more robust.
1 - 6 of 6 Posts
