1 - 3 of 3 Posts
Would someone confirm if I have these steps in the correct order?
1) remove stem faceplate
2) loosen 2 horizontal clamp bolts (does it matter whether the top is loosened before the bottom bolt)
3) release top compression bolt
4) remove and flip stem
5) tighten compression bolt
6) tighten horizontal clamp bolts (again does it matter which bolt is tightened first)
7) re-install faceplate
Done
Dave Hickey said:
That will work fine... The only thing you might want to do is switch 6 and 7. It's easier to center the bars when they are attached.. It's hard to eyeball if a stem is straight without the bars attached
and no, it doesn't make a difference which stem bolt you tighten first
Thanks for the confirmation. That task took all of five minutes!:thumbsup:
1 - 3 of 3 Posts
