Was doing my first cassette cleaning ever since I obtained my (used) bike. First thing I noticed was that the lock ring was ridiculously tight until I managed to loosen it by a few clicks; then it quickly threaded off by finger/hand A bit new to me as lock ring removal on cassettes has been rather gradual in terms of loosening.
Anyhoo, found a foil-like ring between the lock ring and the last (12t) gear; flicking it yields no metal-like sound and it's a flexy as aluminum foil. Also noticed a white/yellow crusty residue around the area which was (luckily) removable.
Trying to make sense of it, I'm thinking the previous owner of the bike didn't realize that the foil piece was probably packaging, so he found himself unable to fully secure the lock ring onto the cassette, then used some substance to keep it together. Makes sense to me, because with that piece in the way, there's no bite at the interface between the lock ring's ridges and the last gear.
...or is that piece holding some type of exceptional significance?
