1 - 20 of 32 Posts
I make Eagles fly
My rt foot gets a ton of pain when I do big climbs. The location is about 1 inch behind my pinky toe and only on the one side. Though it could be shoes, but I have the same problem Teva flats, 510 flats, Garne MTB , 661 MTB and my road shoes. So 5 different shoes on 3 different bikes and massive pain when mashing hard on big climbs.
Any tips on what hat I can do ?
Too many things to consider, I've been there and found out my saddle was 2 mm way too high so that when I was "pulling up" the pedal from the lowest point my pinky toe ended up pressed by the shoe. On top of that I have large-ish feet,moving to a larger toe shoes helped me a lot.
I sprained my foot pedaling 3 weeks ago and had to buy a new shoe that the sole went from left to right completely. The previous weird tennis only shoes had a 1" wide sole in the arch area. Took a week on the new shoes for the foot to stop hurting
They make steel shank shoes for industry that are not flexible. There is a steel plate in the sole to prevent nails from going through. You might try a pair of those if you can get a proper fit. Meanwhile walk up the hills until your foot heals up. If the foot doesn't improve in a couple of weeks, see a podiatrist. Sometimes they have to tape the foot up for the cartledge to get back together again. I had a sprained foot problem that lasted 6 months, and the surgeon I visited didn't know about that technique. He just prescribed more ibuprofen. The podiatrist did know about the tape technique, the foot healed up in two weeks.
I have E size feet, so a lot of shoes are too narrow. Ive had that problem and made it better or disappear by angling cleats like my feet do so the outside part, behind the toe, isn't pressed against the outside of the shoe (so the cleats are toed-in). Give that a try first, before considering wider or larger shoes, which you may end up needing.
TBH, it sounds that your feet also roll to the outside so an insole that lifts to the ball of your foot, or a shoe that already has it like the Specialized, could help.
Get some orthotics for your shoes. Specialized makes some good ones. A good arch support will distribute the pressure on your feet.
I make Eagles fly
I will check with my local dealer on that.
Its odd, anytime I do a bigger climb or do a lot of sprinting I have the problem. Once the pain sets in, even riding the flats or downhill begin to suck. Couple hours after I get home, all pain goes away and I'm good to go.
Nothing else triggers this, I run, hike , etc etc , just riding my road or Mtb.
I make Eagles fly
Discussion Starter · #8 ·
Tried some RP5 shoes on the other day at REI , end if year sale, l, they fit me so much better then the lower end shoes I was wearing. See what happens.
Forever a Student
My guess is your technique and imbalance.
When climbing or sprinting is when you get out of the saddle and apply a lot of foot pressure.
Your pain is on the outside of your foot.
The reason we rock the bike back and forth is so that we can apply pressure with the ball of our foot, not the outside.
I'm guessing you rock the bike to one side, then back to upright, then back to that one side again. So with one foot you're pushing with the ball and then making the other foot push with the outside/pinky area.
To fix this you have to concentrate on rocking the bike evenly left to right and focus on putting pressure on the balls of your feet instead of the outside of them, both of them.
I first noticed myself doing this by using a front camera and watching how the bike was not rocking evenly left and right.
New shoes won't fix anything. The problem shows up in all shoes for a reason, it's a technique problem.
I make Eagles fly
Discussion Starter · #10 ·
Interesting, and I bet attraching a camera to my bike would show how much movement to each side. Will do some tests, right now I'm layer yo with strep throat.
I make Eagles fly
Discussion Starter · #11 ·
Shimano R087 shoes gone RP5 is now used. They require a little break in , but feel great.
Did some sprints, feels so much different with a much stiffer shoe. Rt side felt off, something is off , I can deem more with the carbon sole. Fine tuning, and time to get a nice long ride with some fun climbs, see how they do.
Banned Sock Puppet
I'm wondering if your cleat position might be wrong.
Do you have the same problem if you spin most of your ride rather than mashing?
You might try checking your cleat position as a start. I was having various issues with my bike and got fitted at my LBS. One of the things they adjusted was my cleats. They were too far forward on the shoe (Shimano SPD).
I had transferred the position from my other shoes, which were also set wrong. So if you are setting the cleats the same on all your shoes the issue could be replicated.
In my case I was transferring the position of my cleats from my first pair of bike shoes from 20+ years ago. I guess I had no idea what I was doing then, because the LBS tech took one look and said, oh, there's part of your problem, these are all kinds of wrong.
Banned Sock Puppet
Not written in stone, but as a general rule, cleat fore/aft position should be slightly behind the ball of the foot.
However, for the problem the OP is having, I am thinking there may be a side to side position error rather than a fore/aft position error.
I make Eagles fly
Discussion Starter · #15 ·
New shoes are better, but not perfect
when spinning it it takes a lot longer for the pain to set in. Paying close attention, when mashing, or even just a firm crank, i put my weight on the outside of my rt foot. Left side the force goes in through the ball og my foot, rt side, it’s transmittef through the outside of my foot.
Thinking of grabbing some wedges to change the angle slightly
I make Eagles fly
Discussion Starter · #17 ·
Lack of arch support was my issue causing a similar result. I got a set of the Specialized inserts and it was resolved.
Will try that, being a runner I know that I have high arches.
The Specialized arch supports should be helpful with your high arches. They come in three different levels of support and the right choice should\could help for a lot cheaper than custom orthotics.
Banned Sock Puppet
Others that are good are Pure Stride and Super Feet. Super Feet come in a few different types based on arch height:
https://www.superfeet.com/en-us/
Russian Troll Farmer
Instead of p!$$ing in the dark, just go to an orthopedic arch retailer, get you foot PROPERLY measured, and buy some custom insoles. The $60/pair my insoles cost was the best money spent all year.
1 - 20 of 32 Posts
