Try to find a later model right shifter as it has the improved (more robust) shifter mechanism.Needing a right shifter in Force 10 speed. Or a full set if no one wants to part with just the right/rear one. Would also consider a set of red 10 speed or rival.
I have the later model 10 speed but maybe you are saying I should look at 11 speed?Try to find a later model right shifter as it has the improved (more robust) shifter mechanism.
the 1st gen rival (silver brake lever) and 1st gen force (grey shift lever) were prone to cracking shifter pivot brackets. Particularly annoying as the indexing will keep going out of tune until the pivot eventually breaks, followed by the shift lever falling off.I have the later model 10 speed but maybe you are saying I should look at 11 speed?
