1 - 2 of 2 Posts
· RoadBikeRider
Maybe or maybe not. Forte makes pedals that use a small SPD style cleat and they make pedals that use the larger Look Style cleats. If it uses the small metal cleats it should be fine. If it uses the larger road cleat most likely not. Look at the Performance website and find your pedals and then see what cleat they use. Look at the cleat bolt pattern and that should tell you.
1 - 2 of 2 Posts
