for example Madone in 54cm size is 74 degree STA and Madone 51cm is even more but a 56/58cm is less = 73.5 etc. Look 555 is 53cm is 73.5 etc.rcnute said:I got fitted today and was told I need a steep seat tube angle (like 74-75). Any manufacturers known for steep STAs (like older Looks were known for slack STAs)? Thanks.
Yep, I have long legs for my height with averaged sized femurs, that means I have long lower legs which require a more upright seating position. DiLuca (Liquigas pro) rides a 75 degree seat tube.allezdude said:"I don't understand why you would need a steep seat tube angle, however."
i was fitted at the waterford factory and they recommended a 74 STA for me- they start by finding your knee over pedal center point, then adjust the fore/aft of the saddle until the rails are roughly centered over the seatpost. no doubt I could still ride a 72 STA bike with a longer TT but my saddle would be jammed almost all the way forward on the rails. so, people with weird femur lengths relative to their upper bodies might need a steeper STA. I ride at 60 cm.
tarwheel2 said:GIOS frames all have 74-degree seat tube angles. You can find them at www.excelsports.com. They carry steel, aluminum and carbon models. Coppi is another Italian frame that typically has steep angles.
I thought all LOOK frames had 72 seat tube angles. Has there been a change in their geometry recently?
I don't understand why you would need a steep seat tube angle, however. You could achieve the same fit with a frame having a 72 or 73 angle as long as the top tube length was fitted accordingly. Eg, I used to own a GIOS with a 55 top tube and 74 seat angle, it fit across the top almost identical to my Merckx with a 56.8 top tube and 72.5 seat angle. Sounds like your fitter could use a geometry lesson.
I was thinking how are you going to hook a saddle bag in there if you use one?rcnute said:Thanks, everyone. Now I'm trying to get used to the look of a zero setback post with the saddle slammed all the way forward. Just looks wrong even though the fitter assured me it was copascetic.
