1 - 15 of 15 Posts
I have an old 1988 steel Bianchi with a braze-on front derailleur hanger. I just put on a new crank, replacing a 53/47 with a 47/30 set of cogs. For the small ring, the front derailleur sits about 2 or 3 cm too high. Am I doomed, or is there a way to extend this? Unfortunately I don't think there is quite enough room simply to put a clamp below the hanger.
Banned forever.....or not
Ain't gonna work.
Back in 1988, only little girls would ride a 47/30....A 50/34, or 36 might work.
You can use a round file to open up the braze on, on the bottom side, a little.
Thanks. That's extremely helpful, especially the first part. I'm setting it up for my daughter. I'll let her know.
When I bought the bike in Feb 1988, the gearing was appropriate for climbing Mt. Diablo in CA.
Yeah, I think that is the only hope. Just ordered one...
This is the problem with brazed on tabs.
I've never done this, but is it feasible to carefully grind off the offending tab? So a clamp will fit.
SRAM braze-on front derailleurs have TWO mounting holes, vertically aligned. They permit the derailleur to be used with a compact or standard crank and a brazed-on fitting which I guess is mounted a standard distance from the bottom bracket.
Outfitting the bike with SRAM may be an option.
Discussion Starter · #8 ·
I'm going to try the cheap and easy fix first. I'd like to keep as many of the original campy parts as possible. Also, this is my second frame. I broke the first one within a year or so. It cracked at the FD braze-on, which makes me worry about it being a point of weakness and makes me not want to mess with it. I would rather just put the original crank back on.
I use a shimano clamp... at it's widest point it's not even 2cm.. so hopefully it can fit.
Banned Sock Puppet
I'm thinking you could take a Dremel and grind away some metal on the lower part of the slot of the braze-on.
If that doesn't work, I'm guessing a compact 50/34 would work with the braze-on as is. Might you be able to exchange the new crank? If you really need more hill climbing prowess than a 34 ring can give you, you could probably upgrade the cassette.
Discussion Starter · #11 ·
Well Ive ordered the adapter and hpoefully it will solve the problem without having to get more drastic. Meanwhile, thanks everyone for the suggestions.
Discussion Starter · #12 ·
Confirmed. Fsck me.
I started grinding on it with a dremmel. This will take about 5 years and weaken the attachment, but at least I don't have to grind the frame braze-on.
Did you consider changing out the front derailleur with one designed for a triple crankset? They are designed for 30 tooth chain rings and smaller. I have never used one on a double before but it might work. I hate triples by the way.
I am a 61 year old big guy and ride a 46-34 crank on my Bianchi Infinito with a 12-28 on the back. So I guess Hans and Frans would call me a "girly mon". If you ride fast enough nobody notices.
Discussion Starter · #14 ·
Yeah, I will probably have to do something like that. I wanted to keep the original Crampy. I shimmed it with a washer and it is working reasonably well now, tilted back a wee bit.
Anyone need a partially dremmeled adapter?
1 - 15 of 15 Posts
