It is not a surprise that bikes are normally rear-biased...
insofar as you are sitting on a tube just an inch in front of the wheel. If you have long heavy legs, that is a significant bias. I don't think that there is any point at which an average rider reaches a dysfunctional rearward bias. I think that a rider with even a somewhat upright stance can manuever their machine without undue problems.
When you corner do you put your weight on the outside pedal? When I corner, I often put what seems like all of my weight in 2 places: the outside pedal and the outside handlebar contact point. But I don't shift my body forward, nor do I lean forward, but I do pressure that bar heavily. I have no weight on the saddle or the inside pedal.
I didn't see the thread that you are referring to, but I have seen the rearward slide technique used in pro road racing, and I practice it regularly on my mountain bike. It works.
TurboTurtle said:
For the discussion on another thread about shifting your weight back and braking, I put my race bike on the trainer with the front wheel on the bathroom scale. My normal riding position in the hoods had about 85 lbs on the front wheel. The bike and I weigh about 220, so that's about 40/60 for front/rear. Good? Bad? I always feel light at the front when I corner and lean forward to weight the front wheel - TF
