OK...I'm at my witts end right now. Has anybody dealt with frozen bottom bracket threads before?
My brand new frame came in today and I went to put the bottom bracket on. The drive side went on easy as could be. Then I went to the non-drive side and it threaded on about 3/4 of the way super easy then it got a bit harder (which I figured was left over thread lock from my previous frame). So I used my BB tool and gave it just a small nudge to see if it would break past that point and continue threading.
Mind you it wasn't a lot of force.
It didn't go any further so I stopped and figured I'd back out the BB and clean up the area. Well....the freaking thing won't budge in either direction. It seems like the threads fused together in a matter of no time at all.
I've basically pounded on it trying to get it out and it won't move. I've got to the point of using vice-grips on the BB then pounding on it with a rubber mallet and it won't move...in either direction.
The only way I can figure to get it out is to cut the BB off at the threads, then collapse the inner part of the BB to get it to break away from the threads...assuming they will pull away once I get to that point.
I'm guessing the BB somehow got cross threaded somehow, how I have no freaking clue since it literally spun on 3/4 of the way with no pressure at all, then went maybe a 1/4 turn beyond that and that was it. Chances are the frame is screwed because I'm guessing (based on the BB shell not moving) the BB threads are all messed up now, but I can't be fore sure until I get the BB out of the frame.
Any help would be greatly appreciated....my next stop, when I can get there will be the bike shop...which most likely will look at it and tell me I'm screwed :mad2:
