1 - 1 of 1 Posts
FUJI Bikes SL 1.1 Disc
After purchasing this bike I rode it less than 75 miles as I mostly ride gravel now so it is essentially new.
Like, quick, stable and comfortable with SRAM RED eTAP 11 Speed and SRAM Red Hydraulic Disc Brakes.
Tubeless compatible rims.
Located in Boston area. Prefer local sale and I will have packed and shipped at buyer's cost if preferred.
More images available upon request - pedals and saddle pack exclude from sale.
Thank you for looking.
TECHNICAL SPECIFICATIONS
SIZE
L (56cm)
COLOR(S)
Satin Carbon/Red
FRAME
C15 HC ultra high-modulus carbon w/ High Compaction molding, integrated head tube w/ 1 1/2" lower, PF30 BB, double water bottle mounts, oversized ETC chainstays, flat-mount disc system, carbon dropout w/ 12mm convertible thru-axle system w/ replaceable hanger
FORK
FC-330 carbon monocoque w/ tapered carbon steerer, 12mm thru-axle dropout w/ flat-mount disc system
CRANKSET
SRAM RED 22 carbon, 52/36T
BOTTOM BRACKET
SRAM RED, press fit BB30, ceramic bearing
PEDALS
N/A
FRONT DERAILLEUR
SRAM RED eTAP, braze-on mount
REAR DERAILLEUR
SRAM RED eTAP, 11-speed
SHIFTERS
SRAM RED eTAP HRD, 11-speed
CASSETTE
SRAM RED XG-1190, 11-28T
CHAIN
SRAM RED, 11-speed w/ PowerLock
WHEELSET
Oval Concepts 928 Disc, Centerlock 12mm Thru Axle hubs, 700c 24/28H, Carbon Tubeless Compatible rims
TIRES
Vittoria Open Corsa, 700 x 25c, 320 tpi, folding
BRAKESET
SRAM RED Hydraulic, 140/140 Rotors
BRAKE LEVERS
HEADSET
FSA, 1 1/8" upper - 1 1/2" lower, integrated w/ carbon top cover
HANDLEBAR
Oval Concepts 910SL Ergo, carbon, 31.8mm clamp, 133mm drop, 4° sweep
STEM
Oval Concepts 777SL, 3D-forged & internally machined stem body, +/-7°
TAPE
Oval Concepts 300 bar tape, suede
SADDLE
Oval Concepts X38c with pressure relief zone, carbon rail
SEATPOST
Oval Concepts 950, carbon & alloy, 27.2mm diameter
WEIGHT
15.50 lbs. / 7.04 kg.
Trek, Madone, Domane, Specialized, BMC, Felt, Cervelo, R3, S5, P2, Tarmac, Venge, S-Works, Parlee, Cycles, Canyon, Ultimate CFR, Aeroad SLX, Santa Cruz, Giant, PROPEL ADVANCED 1 DISC, DiamondBack, PODIUM TEAM, Liv Langma Advanced, Pro 0 Disc Road Bike, Pivot, Wilier, Filante, SLR
1 - 1 of 1 Posts
