Greetings:
I'm feeling beaten down this afternoon after having failed to figure out how to make an FSA compact front derailleur work on my Steelman. I run an FSA compact crank, and after a couple of years of non-perfect shifting with a Shimano Ultegra front derailleur (occassional chain deraillments off both the outer and inner rings, along with persnickity trimming), I thought I'd give the FSA a try. After an hour or so of trying every front derailleur trick I know, I was unable to get it to reliably shift up/down across all of the the cogset (9-speed) variations on the stand, which usually predicts bad things on the road. I tried positioning it higher and lower on the seat tube and rotating it inward and outward. Of course, I also monkeyed around with the limit screws until I gave up. I put the Ultegra back on the bike, and, after a couple of adjustments, it shifts like a champ (at least on the stand) compared to the FSA.
There is one thing that could be the problem: I am using non-FSA chainrings on the crank. I put Stronglight rings (48/36) that I had on hand on the FSA crank to see if I like that tooth combo better that the standard 50/34 configuration (I do). They may have different offset/spacing than the FSA ones. Just for the record, the front shifters on my bike are friction bar-cons, so indexing is not the issue.
The FSA front derailleur is very nice looking and seems to have top quality materials and design. I'm not impugning their product; I'm just frustrated that it did not work in my hands. Any and all hints and suggestions would be greatly appreciated.
Best Regards,
Dale
Best Regards,
Dale
