1 - 3 of 3 Posts
What is the best way to remove the non-drive side of an FSA Mega-exo crank arm. Does is require a crank pull arm or is there some new tool to add to my collection?
Thanks
self extracting bolt
I believe most mega exo cranks come with a self-extracting bolt for the non-drive side crankarm.
Thanks
Can't speak for the Megaexo
but if it does not have the self extracting bolts FSA has used a different size crank puller. I found that out with my FSA Carbon Pros. Had to buy the Park CCP-4 for Octalink/ISIS. http://www.parktool.com/products/detail.asp?cat=26&item=CCP-4
The FSA website detail on MegaExo all looks like they use self-extracting bolts, so you should be fine.
1 - 3 of 3 Posts
