1 - 7 of 7 Posts
Beatchin' Technology
If you traverse a slope while cycling up it, does the Garmin accurately calculate the slope of the hill? I.e. Some hills are too steep to ride straight up :cryin: and require me to traverse. If you are crossing the slope while traversing, would the Garmin (in Training Center) show a lower slope than if you rode straight up it?
Garmin will calculate the slope you actually ride. If you zig zag to make it up a slope your distance will be further than if you were to ride straight up. slope=rise/run since the rise is the same but zig zagging increases the run, the effective slope is decreased. This is all theory. I am not sure how accurately a Garmin will record that.
I'm slow
What BCH said, however...I find the slope display option pretty much useless on my 310XT. As BCH said, the slope is determined using the rise/run. The problem with the 310XT is that the elevation uses only a GPS calculation and not a barometric altimeter, which makes its accuracy highly questionable. (This can be corrected post ride by comparing data to known reference values) The 500 and several other versions use a barometric altimeter and are much more accurate. I've tried using the slope feature and it tells me nothing more than what I can guess just by looking at the road. Your results with a different model may be better.
Discussion Starter · #4 · (Edited)
One clarification
The slope that I am talking about is that indicated in the Training Center software. Not the slope on the display of the Garmin Edge 305, which has a barometric altimeter. The slopes displayed on the unit are steeper than those indicated on the Training Center software.
For example, I got 22.5% on the Training Center file as the steepest slope on Fiddler's Elbow (Jersey) on Sunday. On the steepest pitch of the road, I had to traverse at 1mph to climb it. It occurred to me that the traversing reduced the pitch that the Garmin was 'reading' because I was covering more horizontal distance to ascend the same vertical feet.
Premium Member
Both previous posters are correct. For best results you will certainly want a Garmin with a barometric altimeter, like an Edge 305, 705 or 500 (and perhaps preferably with the GSC-10 speed/cadence sensor in the case of the 500). However, I still would not expect total accuracy with their grade measurements. In your case the tight back-and-forth switch-backs will probably tend to reduce the distance measured (due to the GPS sampling and averaging) leading to a slightly higher grade than what you actually rode. If you really want your Garmin to measure the actual grade of the hill, then I am afraid that you will have to ride straight up it!
Someone also makes a grade-o-meter device (works like a spirit level) that you can mount to your bike.
Master debator.
We have a few hills around here marked by the DOT with grade percentages for some reason, probably a survey. My edge 305 is usually right on with them.
1 - 7 of 7 Posts
