But it's easier to buy a weight reduction.Exactly! Much less expensive to lose 6 lbs off the engine.![]()
Sorry, the total build on the video is 21.5 lbs. A UCI level bike is 15lbs.Exactly! Much less expensive to lose 6 lbs off the engine.![]()
Exaggeration, don't you think?More like 2-3 lbs at most.
Oops, I quoted the wrong post initially. No exaggeration at all. The bike in the video is 21.5lbs. They talk about it. It’s comparable bike today is 15lbs. I’m no mathematician but 21.5-15 i= 6.5. That’s a significant difference. That is more than double what you predict.Exaggeration, don't you think?More like 2-3 lbs at most.
There are steel road bikes that weigh under 20 lbs. And how much would you have to spend to get a 15 lb bike? I know that both my carbon bikes weighed shy of 18 lbs stock.Sorry, the total build on the video is 21.5 lbs. A UCI level bike is 15lbs.
As @DaveG said, frame weight is less than half the equation. Wheels and components weigh more than the frame.Oops, I quoted the wrong post initially. No exaggeration at all. The bike in the video is 21.5lbs. They talk about it. It’s comparable bike today is 15lbs. I’m no mathematician but 21.5-15 i= 6.5. That’s a significant difference. That is more than double what you predict.
The topic is Modern BIKE vs Retro BIKE. Not steel frame vs carbon frame. Not most expensive bike vs some other goal post.There are steel road bikes that weigh under 20 lbs. And how much would you have to spend to get a 15 lb bike? I know that both my carbon bikes weighed shy of 18 lbs stock.
I for one have no rabid preferrence for either material. I just think the argument that one frame material is so much better or weighs so much less is ludicrous.
And obviously, the video cherry picked two particular bikes. You can make a light or a heavy bike out of any frame material.
My steel bike weighs 17lbs. That has absolutely nothing to do with the the comment.There are steel road bikes that weigh under 20 lbs. And how much would you have to spend to get a 15 lb bike? I know that both my carbon bikes weighed shy of 18 lbs stock.
My d!ck is way lighter than your d!ck and still meets UCI limits! 🤣Unless one is racing a bike for a living or is seriously competing it all just becomes a dick measuring contest, not much different than who has the biggest pick-up or fastest car.
When bikes are under the UCI weight limit, they have to add metal slugs in the tubes.My d!ck is way lighter than your d!ck and still meets UCI limits! 🤣
with the right slug it'd be almost like walkin' around in a constant state of arousal, like being 17 again.When bikes are under the UCI weight limit, they have to add metal slugs in the tubes.
Make sure you don't go under... or you'll have to add a metal slug to your... ummm .... tube.
Metal slugs never did it for me even when I was 17.with the right slug it'd be almost like walkin' around in a constant state of arousal, like being 17 again.
At 17 a penile prosthesis implant wasn't needed.Metal slugs never did it for me even when I was 17.![]()
