As it's the highest gear possible on a "normal" bike (one without custom {over}sized rings) and the same gear that top pro racers use for going "very fast" - either downhill or in a sprint. If you can't use it on your rides (I couldn't) then it would be a wasted gear. It would be the equivalent of me having a 500lb barbell in my basement - useless.How to chose between the two crankset ?
What is the 53T/11T gear for ? High speed down hill pedaling ?
For most people - climbing hills. If you're not fit or not strong then, yes, it might be for your high speed cruising.Is the 39T or 34T for high speed cruising?
Only you can answer that one. We're all of different strengths. If you give us some idea of what your true average speed** is, then we can give you an opinion of the possible gear you should be using.Which gear for high speed cruising in normal flat road?
Good luck and have fun. Your welcome.I'm kind of weak rider and still need a lot of training to become decently strong. I think my option in crankset will be 50/34.
'...What do you consider high speed cruising?...'
I really don't know since my 1st road bike is still under construction. I got the frame & fork/wheel/bar & stem/saddle & post only.
'...Most cyclists can better use a 50/34 than a 53/39. If you need 53/39 you will already know that you need it. ...'
I'm absolutely belong to the 'most cyclists' group.
Thanks.....
