1 - 12 of 12 Posts
looking at switching from my compact crank and 11/23 cassette to standard crank. What would be a comparable cassette for the low end clibing gearing to the 34/23 that I have now. would a 39/25 be close or 39/26? i need a bit more top end speed but am not the best climber and like to spin vs power up climbs. Only looking to switch for better sprinting gears.
'brifter' is f'ing stupid
you'd have the same low gear w/ a 27, so you're probably gonna want an 11-28(which would be slightly easier on the low end) or an 11-26 (which would be slightly harder on the low end) since i don't think anyone makes an 11-27.
thanks for input. mainly looking to switch out due to sprinting efforts. ive noticed this year that on faster sprints i dont feel real comfortable with the cadence that the cmpact gearing gives me. at 30 it just doesnt feel good out of the saddle. cadence is too high and I think i might feel better at higher speeds if i was in a bigger gear.
simple...
You need a 12-27. 23/34 x39 = 26.4 Your old 50/11 top gear is just a little higher, but a 53/12 is very close.
this might be stupid but.. how about getting a larger big ring?? keeps the same low gearring for climbing.. but higher top end which if I`m understanding right.. is what your after? ( not sacrificing low-end but gaining high-end )
With a 50/11 it only requires 91 rpm to go 30mph. With a 53/11 it would take 86 rpm.
That's not sprinting, it's a snail's pace.
Hucken The Fard Up !
53-39 12-27 for hills/mountains and keep the 11-23 for flats/rolling hills/sprints
Slightly Opinionated
/\/\/\/\ This is correct.
Discussion Starter · #9 ·
i dont believe that the derailluer can push the chain from the small 34 on the compact up to a 53. would have to be the 53/39 combo since I have Campy. I think shimano and maybe even SRAM have some in betweens like a 52/36 which would be perfect for what I think I need. not sure im gonna switch over from Campy right now though.
thanks all for the advice I think I know which way Im going
Team Astana rode 53-34 x 11-28 in stage 15 of this year's Giro d'Italia. Might not be as smooth as it could be and probably needs a chain catcher.
Anything you can do with a normal crank you can do with a compact. I'm not sure what it is you don't like about your compact, but you can also get a 51 or 52 ring for that crank. There's absolutely no reason to change everything just to get slightly different gearing.
Old Skool
Spin faster...
My feeling is sort of a subset of what C-40 has said. A cadence in the 90s is not excessive. IMHO, you should learn to spin more smoothly and wind out the 50x11 a bit more. At 120 RPM your 50x11 will produce about 43 MPH. If you spin smoothly 120 RPM should not be even close to spun-out.
If developing a smooth spin seems impossible, my advice would be to take a close look at your saddle position.
Just my $0.02...
1 - 12 of 12 Posts
