1 - 8 of 8 Posts
I just rode across an area where the road crew was paving. The guy waved me through on fresh blacktop. My tires were coated with sticky goo. I rode home, and picked up every pebble in the county. My tires look like aggregate driveway!! So, what is the best way to get that stuff off? I already cleaned and degreased the bike. It looks good. I tried Simple Green degreaser on the tires, but it did very little. These are my new Hutchinson 5 tubeless tires, too! Thoughts?
Forever a Student
Have any of that stuff in the garage for removing bugs from the front bumper? If so that might work.
You could try riding it off. I've done that with good luck.
I cleaned off what I could with white vinegar, and that has helped some. I don't want to use anything that could weaken the rubber. At this point looks like I will ride off the rest.
I scrape off as much as I can with a dull steel edge (like a butter knife), then just ride until the rest comes off. I'd avoid solvents.
  • Like
Reactions: dndrich
Now, that is a good idea. Wish I had thought of it! Well, I used vinegar, but the tire looks OK.
Banned Sock Puppet
Arrrrrggghh!!! Been there, done that! :mad5:
What worked for me was riding a mile or two more until dry dust, road dirt and tiny pebbles made the tires just a little less sticky. But in case you didn't notice, pebbles stuck to tires slow you down and make a very annoying sound while riding. :mad2:
I then stopped, got a rag out and wiped all the stuck pebbles off. After that, I just rode the rest of the goo off as it wasn't sticky enough anymore to pick up pebbles.
You could try the vinegar idea if you want. I wouldn't use tar remover or any harsh solvents on tires.
Kerosine will dissolve tar. So will Engine Brite. It will probably dissolve your tires too. I have found the butter knife to be the best bet.
1 - 8 of 8 Posts
