There are a bewildering number of product possibilities for the road cyclists in your life, but fear not. Here is a selection of gifts ideas for everyone from the budget-minded to big-spenders.
Want more gift ideas?
GIRO SYNTAX MIPS ROAD BIKE HELMET
When it comes to racing your road bike, you want to make sure you have a lightweight helmet that is aerodynamic and well protected. The Giro Syntax MIPS Road Bike Helmet that is a lightweight helmet that has slightly deeper coverage and high-performance features. It has a molded, tough polycarbonate outer shell and an EPS foam liner. It features a highly-adjustable Roc Loc 5 Air MIPS system so you can dial in the perfect fit. The MIPS system helps redirect impact energy.
GARMIN EDGE 830
The Edge 830 provides you with all the basic features you come to expect like speed, time, distance, and elevation, but has been loaded with a handful of new features as well. The navigation capabilities of the device have greatly increased with preloaded Trailforks data including difficulty level, the display screen has increased by 13%, and battery life is now a claimed 20 hours.
ORBEA ORCA M31E TEAM BIKE
Whether you're conquering a tall mountain for the first time, competing in a crit race, or you're just trying to beat your PRs, you'll want every advantage you can get. Things like a stiff, lightweight, and capable bike will help you get the edge over the competition. The Orbea Orca M31eTEAM Bike is the ultimate road racing bike. It has an ultra-light carbon fiber OMR frame that has monocoque construction and internal cable routing. The frame is power meter compatible, has thru-axles on the front and rear, and has Speed release compatible dropouts.
100% SPEEDCRAFT SUNGLASSES
Feast your eyes on some of the most advanced sunglasses on the market. The 100% Speedcraft Glasses are lightweight performance riding glasses that come in an array of colors and lens options. These glasses feature a durable TR90 frame to keep the weight to a minimum and the lens is made prom durable polycarbonate. The Speedcraft is also available with HiPER lenses, for the ultimate in optical clarity and every lens features Hydrolio lens treatment, which repels water dirt and oil from the lenses. The Ultra-Grip nose and temple pads makes for a comfortable fit and 100% includes two sizes of nose guards, so you can find the one that fits you best. Included with the speedcraft is an extra clear lens, a carrying case and a microfiber bag.
FEEDBACK SPORTS RIDE PREP TOOL KIT
The Feedback Sports Ride Prep Tool Kit comes stocked with the essentials needed to tune up your before or after a ride. It features 12 tools with up to 16 different functions with professional grade and durability. The case can conveniently be attached to bicycle works stands for easy access to the tools you need.
SILCA SUPER SECRET CHAIN LUBE
Lubricant is paramount when it comes to your chain's performance. Without proper lubricant, your chain could wear out prematurely. The Silca Super Secret Chain Lube keeps your chain silent and smooth. It utilizes the world's fastest, most lubricious additive, nano-scale Tungsten Di-Sulfide. If you're looking to maximize performance through friction reduction, then you'll want the Silca Super Secret Chain Lube.
SHIMANO SH-RC902 S-PHYRE ROAD SHOES
The shoes you use while you're riding play a significant role in your performance and pedaling power. With a stiffer sole, road bike shoes are able to put more power from your legs into your pedals so you can accelerate faster. The Shimano SH-RC902 S-Phyre Road Shoes are the ultimate road competition shoe with a supremely engineered fit and optimum power transfer. These shoes feature a 360° surround wrapping upper that creates an exceptional fit, a heel cup with anti-twist stabilization that secures optimal foot positioning, and dual low-profile Boa Li2 dials so you can make micro-adjustments and dial in the perfect fit.
SPECIALIZED AIR TOOL HP PUMP
Keeping your tires inflated not only helps prevent pinch flats, but it also helps riders go faster. The Specialized Air Tool HP Pump is designed to high-pressure tires and inflates them with minimal effort. It will pump a 700c tire up to 100 PSI with 30% less effort. It features a 2.5" oversized gauge so you can accurately see what pressure your tires are at, and it has a steel base and aluminum barrel. The ergonomic wing handle makes it easy to keep pumping and the 42" hose makes pumping easier at any angle.
GARMIN RALLY RK200 POWER METER PEDALS
Track your performance with the Garmin Rally RK200 Power Meter Pedal. Featuring an upgraded, dual-sensor design, the RK200 can measure total power, cadence, left/right balance, standing vs. sitting pedaling, and power phase. These pedals install just like any other pedal and are compatible with LOOK KEO cleats. The Rally series is compatible with Garmin Ecosystem and works with the Garmin Connect App, as well as Strava, Training Peaks, and Zwift to sync your ride data. The battery can last up to 120 hours and the pedals weigh in at 326 grams.
Jenson USA Gift Card
Make gift-giving easy and guarantee the mountain biker in your life will get exactly what they want! JensonUSA gift cards never expire and can be used online, in our retail locations, and over the phone. You can choose a physical gift card, ideal for use as a stocking stuffer, or an E-gift card that's delivered the same day.
Still searching for the perfect gift?
Click here for more holiday gift ideas from Jenson USA.
GARMIN EDGE 830
