1 - 20 of 28 Posts
I find them to me completely useless. I tried to fix a flat with them last night and the patch kept blowing off at about 100 PSI. Got so mad that I threw the tube and patch kit away. Just ordered 3 new tubes and patches with glue...
Shirtcocker
yup....
//they do work OK for lower pressure tires IME
Carbon Fiber = Explode!
mohair_chair said:
I've never gotten one to work. They are easily the most useless cycling product ever created.
+1
Never ever got them to work. Park Tools, Slime, Bell... you name it it doesn't work.
Maybe it does for MTB low pressure, for road, USELESS
Bikespace member
FAIL :yesnod:
i've used them several times, all with success. I actually used one last week, pumped it up to 110psi and it's still holding air just fine.
I carry them with me, and I've used them several times out on the road and have never had a problem. I find them to be very handy and convenient. I've even patched tubes quickly with them without taking the wheel off.
Matnlely Dregaend
They work ok if you make sure you get all the white releasing agent off the rubber before applying the patch. I don't know how you get 100+ psi with a handpump, someone must be using their wrist more often then me... They're perfect as a temporary patch. When I get home I put on a new tube.
Just Riding Along
Been using them successfully for 2 years, until 2 weeks ago. The tire lost pressure after sitting for 2 minutes at 80 lbs (it suddenly just went pssssssssssttt), but when I demounted the tirea and removed the tube, the patch was holding. Finally, in frustration, which was compounded by the fact that these were the tightest tires I ever mounted, I threw the tube away. Now, thanks to your post, I understand what happened.
I use proper patches at home, but I sometimes carry some glueless ones in my pocket whem I'm riding, just cos there's less to carry around. Last weekend the glue on the glueless patches I was carrying became mobile (it wasn't a hot day, so I'm reluctant to say it melted) and ran all over the pocket of my best cycling jersey... grrr
duh...
you didn't clean the tube before patching? no wonder it failed
It's Good For You!
I've used them for a few years with no issues. I've even patched a leak in my camel back that I use for mtb. You really need to make sure the tube is clean and free of talc for it to stick well. Other wise, I can see issues.
Bike Dude
You have to sand the area a little bigger than the size of the patch. Use the little metal grater that comes in the kit or substitute a small square of sandpaper or small sanding disk. And clean the tube before you patch it.
Resident Curmudgeon
I don't like'em either. Give me the good, old fashioned sand the tube & glue it on patches. I've very rarely had one of those fail.
1 - 20 of 28 Posts
