gardenrunner said:
Were you trying to say that the body depends on fat as it would glucose after a certain amount of hours? Otherwise, sdeer would be correct. That's why endurance atheletes are so damn skinny and have hardly any body fat. After training a certain amount of hours(I believe it's 3 +) the body starts to use your fat stores as fuel. This is also why after 2-3ish plus hours of training you need some protein intake or your body will turn to it's own protein(your muscles) and thus leads to muscle cannibalization. Correct, sdeer?
For those with out an exericse/metabolism background, this gets kind of complicated. But to keep it somewhat simple....
To start out, you are always burning fat, carbs, and a really small amount of protein during exericise. The amount of fat and carbs depends on the intensity, duration, feeding, and a combination of these factors. Your body prefers to burn carbs, as it "likes" to have muscle glycogen available. Training increases the mitochondrial density (size) and blood flow (capilary density) to muscle which allows for greater use of both fat and glucose during exercsie. The more ATP you can produce, the more work you can do.
Your body uses what it has available (CHO or FAT) for energy during exericse, but has a "preference" for glucose. So, if you exercise at moderate intensity (zone 2 -3) after an overnight fast or for more than 1.5 - 2+ hours into an event without eating again, you use quite a bit of fat for energy coming from adipose tisse and IMTG's. However, you are always burning glycogen as it is a perfered source of energy and readiliy available in muscle tissue, but in the absence of exegenous (from the diet) carb intake, glycogen can "run out" making the oxidation of fat "more difficult". This is the bonk, or hiting the wall as glycogen is runing low and the the enzyme that cuts off glucose is not able to further debranch gylcogen. You never truely run out of glycogen until you die, you just get so low that the "branches" are too short for the enzyme to cut off more glucose. Additionally, exericse in the fasted state is not as good from a performance standpoint and typically does not translate into greater "fat loss" as calories are replaced post-exercsie. Energy balance is the driving factor in body weight and to a certain extent, body composition.
If you eat (carbs) before exercise, then you have glucose available in the blood and in the muscle as glycogen. Glucose oxidation is increased as it "competes" (more of it right there) for oxidation with fat (that is coming from IMTGs and adipose tissue). So you burn less absolute fat, but the same amount of "calories".
Absorption of carbs from the gut is limited at high intensity (less blood flow to gut) and increases glycogen and fat use. However, gylcogen and blood glucose are "faster" sources of ATP during exericse and seem to outcompete fat to provide acetyl-CoA's for the TCA. At high intensity, fat is still being used, but a much greater contribution is coming from glucose/gylcogen. Lactate production is increased as pyruvate is "backing up" for entry into the TCA.
As far as protein breakdown in the muscle is concerned, it is relatively constant. Protein provides a small amount (relatively) to energy and/or glucose precursors. Protein synthesis (rebuilding muscle tissue) can not take place during exercise as AMPkinase activity inhibits downstream protein synthetic machinary. The latest data show no benefit of adding protein to CHO drinks other than satiety. But post workout/race protein and adduquate and often CHO/Protein are required for recovery.
Endurance athletes have low fat mass due to a chronic negative energy balance. They burn so many calories during training and racing and then do not replace them all before the next bout (next day) of training. We (athletes) use a high relative and absolute amount of fat to provide energy at rest and after exercise. So the slight negative energy balance over time, leads to less fat in adipose tissue, as energy (calories/CHO/PRO) is used for recovery, glycogen replenishment, and muscle protein synthesis.
