1 - 10 of 10 Posts
Hello everyone. I've been doing research into what's available for light touring and gravel riding rims for a while now, and I'm just wondering if there's anything that I haven't considered yet. I'm looking for 700c/29" rims with an internal width of 20-24mm and a moderate depth of 20-30mm. Will be running tires anywhere from 32-40mm. Rims that I've been looking at include:
HED Belgium C2+
Velocity Aileron
Velocity Dyad
DT Swiss TK540DB
I really like the dimensions of the HEDs, but I'm not sure about their ability to stand up to prolonged abuse. I have the same worries with the Aileron, but I know the Dyad can withstand it. The Dyad is just narrower than what I'm looking for. So with all that, I keep coming back to the DT TK540. So who's out there and what are you using?
Banned Sock Puppet
HED Belgium C2+ if you're flush.
DT Swiss TK540DB if you're not.
I would avoid Velocity. There are better choices.
I would also cast a vote for HED Belgium in either the standard C2 or Plus depending on your preferences in width. They also come in a variety of spoke counts to suit a variety of riders/applications.
They are about as good of an all around rim choice as you'll find.
NewRoadEnthusiast-Again
I can't give you high-mileage anecdotal experience, but I haven't heard or read anything negative about Stan's Grail rims. If you're doing disc brakes, they fit your specs.
I had mine built with a 32 hole rims, a Shimano Nexus dynamo hub on the front and Deore XT hub on the back. I only have about 600 miles on them, but so far, so good.
Banned Sock Puppet
The WTB Frequency Team CX i19 or i23 work great tubeless, are cheap and are very durable.
These do look promising. I haven't seen anything bad on them.
I don't see the need for a heavy duty rim for gravel or light touring. You've got this big cushy tire protecting the rim vs a skinny road tire on road bikes.
Banned Sock Puppet
I am getting ready to build up a 27.5 wheel set using WTB KOM i25s for my gravel bike. I will be using 47mm WTB Byway tires with them.
The KOM is a lighter version of the Frequency.
1 - 10 of 10 Posts
