1 - 20 of 27 Posts
I am looking to reduce my stable of bikes from 4 to 3. I will keep my hardtail 29er and my Trek Madone for road racing and fast group rides. Therefore, I'm looking to replace an old cx bike, which I use for, in the order of importance:
1. indoor training/zwifting, both on the rollers and trainer.
2. road riding when the weather isn't ideal. I ride the cx outdoors pretty much exclusively from November-March because of the salt in MN. I never ride the madone if there is rain forecasted either.
3. Gravel races. I do some long 4-7 hour gravel races every year with a lot of climbing and some pretty steep hills.
4. Slow road rides, like B paced rides and rides with my wife. The madone doesn't like to go slow.
5. Cyclocross races. I've never done one, but they look fun and I might jump in this fall. Not good for my motor though.
Budget is about $1,100, and I need a 61cm or above, since my inseam is 37 freaking inches. Would prefer to buy used for better value.
I think I'm looking for aluminum, because carbon is too expensive and doesn't mesh well with hours on a trainer, and steel melts in the salty MN roads and under my sweat from said indoor trainer. I would like something as light as possible. Clearance for at least 35-38mm tires is a must.
I think something like the bmc gf02 disc would work, but I don't know what else to look for. I found a 2015 61cm gf02 disc 105 used for $1,100. I also have a good friend who is also 6"4, and has ninja status on Trek U. The crockett 5 disk is therefore in my price range, or I could get a crockett frame and transfer the parts from my old cx to it.
A Crockett doesn't have a lot of clearance for a gravel bike in my opinion, but it depends on what your gravel looks like I suppose. To me a gravel bike needs to be capable of 40mm tires with clearance for mud build up.
Yeah, I would agree, but my priorities are such that I can't have a dedicated gravel bike, and I mostly ride my cross bike on the road. I've only ridden gravel on 35mm, at 45-55 psi, because a 38mm won't fit in the rear of my current cross bike, and that's been fine for me. Greater clearance is certainly good, but MN gravel isn't too bad- we don't have super chunky fire roads, and even if we did, and I did a ride on them, I'd use my 29er. Not sure I'd even use a 40mm for gravel here if I had the choice; some guys do, but they're usually slower than me;)
What about the specialized Diverge? I guess I'm looking for a reasonably fast endurance road bike that can fit 35mm tires.
I ride my Niner on the road all the time in bad weather, including snow during the winter, and on the trainer - so it's not a dedicated gravel bike but it is certainly a very capable serious gravel bike when I want it to be. It doesn't hurt having extra clearance, and it's got good endurance geometry. If you really get bit by the gravel bug you may end up riding outside MN in gravel where you want bigger tires. Not trying to talk you into big clearance bikes, just pointing out its not limiting and may open options you want later.
A Niner RLT 9 would be amazing, but I doubt I'll find a 62cm used for around a grand. That's a good suggestion though.
I have the Diverge DSW with Tiagra, I run 32s with no problem, plenty of room for 35s. It retails for ~$1400, so you should definitely be able to hit your price point.
Rear wheel is a standard(?) QR, so you should be ok with the trainer as well.
Competitive Cyclist has a 62cm frame set for sale for $1050, move parts from you cross bike to it.
Sir Descends-a-lot
i vote crockett. it can fit 40mm tires no problem. i currently have mine set up 1x11 with a 40t up front and 11-36 in the rear. gevenalle shifters, wtb cxi19/dt350 wheels. super fun bike, quicker than youd expect. i use it basically as you intend to you use, it goes on my trainer, it goes outside when salt is on the road, i train on it, do tempo rides on it, hob curbs, ride down stairs. its really a sweet bike. trek just released the 2018 crockett yesterday so you can probably get a deal on a 2017 if you poke around
Discussion Starter · #12 ·
Hmmm...looks like they do have a 62cm, but 1050 is right at my budget, that's a lot for a frameset, and I wouldn't be able to move my wheels over. nor my bb and crank without an adaptor.
Cross check is steel, right? That won't work. Also want disk.
Discussion Starter · #13 ·
How stiff is the crockett around the bb area compared to a 700 series carbon frame? Does the fork transmit every vibration to your hands or is it more forgiving?
Not with much room between the tire and chain stays - a couple mm at most on the DS. I do like the Crockett, if the OP can get by with 35mm tires at the highside he's got enough clearance on the rear to clear a little mud or a broken spoke.
With fat gravel tires its smooth, road tires not so much - it does have a carbon fork and steerer though you know. Double wrap the bars if you get too much buzz on the road.
I'm 6'4" and use a 64cm frame emonda sl6 road. I'm also leggy like you and have about the same inseam. I picked up a trek crossrip 3. It's about $2k new, but it's aluminum, disk brakes, 105 components, and I've put 40mm tires on it with room to spare. It's a 61cm (largest size) and my fitter was able to give me the same fit on the crossrip as I have on the emonda. I haven't had much time on it yet as I bought it late season last year, though.
Discussion Starter · #17 ·
Ended up scoring a 2016 bmc GF02 disc 105 off ebay for 707 bucks including shipping. It's a 61cm, and the geo looks like it should fit. This one has hydraulic disks too. Pretty excited for it to come.
Does your cycle cross bike have disc brakes? If it does, you could check into 650B wheels.
I took an old frame and converted it. I can run 38s without any issues. Would be an inexpensive way to have the best of both worlds
I have the Motobecane Omni Strada Comp from Bikes Direct for $1K. I've rode 3 rides with it (about 100 miles) and it's been great. The Motobecane has 105 components, aluminum frame and hydraulic disc brakes. After I received it from Fedex, I took it to the LBS (still in the box) to have it assembled and fine tuned. My Moto is a 55cm, but they are available in 61cm. Also.... it has clearance for 45c tires, but I really like the 40c WTB tires that came with it.
Discussion Starter · #20 ·
Bicycle frame Bicycle tire Bicycle wheel Wheel Tire
For 700 bucks, this was a steal. Full 105 group with TRP hyrd brakes, less than 400 miles, and it even fits. It's pretty responsive and not the cushiest bike ever, and there is definitely not going to be clearance for 40 or even 38mm knobbies, but for my needs this should be great.
1 - 20 of 27 Posts
