1 - 3 of 3 Posts
So. Calif.
Decided to split this off from the thread "Grease for Campag Hubs".
I just received a small vial of Shimano # Y3B980000, "Special Grease for Freehub Body 50g" and I think it will be an excellent choice for lubricating shifter body internals. Priced around $12 @ Amazon.
I'd guess it's around NLGI-1 consistency, thinner than toothpaste, but not as thin as Shimano # Y04180000 "SP41 special grease" for cable housing. The latter might be an NLGI-0 grease.
The Freehub Body grease is a very light tan color, creamy, and non-tacky. Who knows, maybe it's even re-packaged Kluber NB52.
I typically use heavy SAE 80 oil for lubing freehub pawls, but might give this Shimano grease a try.
I think Freehub Body grease is too light for uses such as wheel hub, crank, or headset bearings.
The bright green Dura-Ace grease # Y04110000 / Y04110200 seems a good choice for that, and also other good options for hub bearings.
Doesn't like subtitles
I've never had to take any of my Campy shifters apart (except for the old school DT shifter) and never had to lube them. When I used Shimano they would gum up all the time and I would hose them with WD 40 but never with Campy. I suppose if I felt the need to lube from the outside I would use Boeshield T9 or Wd 40.
I've rebuilt and repaired my Record 10 shifters twice. I used Finish Line lithium grease (white stuff) that seemed to best match viscosity and consistency of the factory grease. I've ridden in 90+ and Sub-Zero temps and it performs well.
Sent from my Nexus 7 using Tapatalk
1 - 3 of 3 Posts
