You grease the spindle/shaft where it contacts the inner races of the bearings and the inside of the inner races(assuming a cartridge bearing BB.) Grease threads and splines. Any grease will do.Hi All,
I'm doing a straight forward crank swap Ultegra to D.A. The grease is only in the B.B. right? so I don't have any of the fancy DA grease! Do I need to put grease on the new shaft?
Thanks
