1 - 12 of 12 Posts
Hi peeps,
So I'm in the process of acquiring myself a new Pegoretti. It'll be running chorus 11. I've got a set of ksyriums that'll go on initially but I can see myself upgrading reasonably soon.
I am leaning towards a handbuilt, semi-aero tubular wheelset. Boras are too expensive, so it's the handbuilt route for me. Need to be strong-ish (I'm 200lb on a bad day), and aeroish like I said before. Weight is not too much of an issue, if they come in around the weight of the ksyriums (equipe) or a little less I'll be stoked.
So here's where I throw it open. Thoughts? What components should I look for? DT Swiss hubs? Sapim spokes? Velocity rims? It helps that they're made here in Australia ;)
Thanks for any replies!
You really want tubulars? For clinchers in Velocity, I'd go with the Fusion, which should be very strong, or the Aerohead and Aerohead OC, which you'd want a little higher spoke count for. I'm tempted to try the new 23mm A23. In tubulars, the Escape looks fine.
Fuss is right, they're a huge pain in the arse! Very close to zero road riders still use them.
They're still often used for racing for two reasons:
Lighter weight (the rims, mostly).
They can continue to be ridden on, while waiting for a new wheel, better than clinchers.
A wheelist
irongustavius said:
Guess I can use clinchers with some Open Corsa CXs or such?
Lovin' mine. I run them at about 80psi (25mm wide. 170lbs bodyweight) and they're like a breath of fresh air. They're fast and comfy. I wouldn't use tubulars again if they were free - and I did use them for 24 years.
In that case, what would be a reasonable strong + aero handbuilt combinarion?
Look at BWW Blackset Race - light, strong AND "cheap". Mine are excellent.
A "handbuilt, semi-aero tubular wheelset" for campy? Ok:
Campy Record Hubs (32 hole) - who thought there would be a day when these would be cheap? You can get them from various UK online shops for <$200. A DT swiss rear hub is north of $350 now. Mine weighed in at 115g for the front, 231g for the rear. Come in tuxedo black.
Kin Lin TB25 rims - 27mm profile. Tubular. 430g. Strong enough for CX if you want to. Come in every colour you want, if you want black. Can be had for $60.00 a rim.
Lace 'em up with DT swiss competition spokes (black), 3x all around. Brass nipples. $72 bucks.
There is a bombproof tubular, semi aero wheelset that will set you back less than $500 and weigh in around 1600g. They will last forever. FOREVER. You could ride a cobbled classic on these. There will be 13 speed campy before these start to wear.
Want more bombproof, but willing to give up aero? Go with Ambrosio Nemesis rims...
Discussion Starter · #12 ·
Campy Record Hubs (32 hole) -. . . . Come in tuxedo black.
Kin Lin TB25 rims - 27mm profile. Tubular. 430g. Come in every colour you want, if you want black.
lucky I'm leaning towards black, huh.
Thanks for your help. I'll talk to my bike shop, see what's available. I'm not up to building my own just yet.
1 - 12 of 12 Posts
