1 - 20 of 29 Posts
I'm about to order a new handlebar and have only used the round type in the past.
Is there is any advantage or disadvantage comfort or other wise for the newer flat type bar over the traditional round type in your opinion?
Thanks in advance.
waterproof*
Yes. I went from a flat carbon bar to a round aluminum bar and no doubt the flat bar was more comfy.
Poseur
I switched from a round bar to a 3T Ergonova Pro a few months ago and don't think I will ever use a round bar again, except on a fixie. It is definitely a lot more comfortable than a round bar.
I have flat bars on my road bikes and I don't think I will go back to round bars. Flat bars are much more comfortable on long rides.
corning my own beef
while I really prefer the aesthetic of a round bar (with traditional bend), I ride a flat-top bar for the increased comfort.
n00bsauce
Zachariah said:
Flat tops unanimously...
Wait a minute. I've got both and I'm not partial to one or the other. Both work fine. What's more important to me is the bend. Make mine shallow and NOT ergonomic.
I don't like flat bars. Perhaps if I rode with my hands on that spot more often I would but generally I'm only there for portions of climbs where I want to have a good firm grip and round bars are better for that.
Rub it............
I prefer a round bar over a flat-top bar. Probably because I spend very little time on the tops of the bars. I usually stay on the hoods, or just aft of the hoods.
Don't care
Since I spend approximately zero percent of my riding time where the flats would be on a flat bar, I just don't care :)
Höchstgeschwindigkeit
Purely a preference item... you choose. I prefer a 34 cm bar rather than 32 and shallow drops. The 3T Limited Ergosum round is great for me. My last bike had flat tops...liked them too but if you get too comfy on the tops you are too far from the break levers.
This space for sale
I recently switched to 3T ergonova bars and find them a lot more comfortable than my last bars. I think it has more to do with a shallower traditional bend rather than the anatomical easton bars I had prior.
Baltic Scum
I find my comfort level much more influenced by saddle position/tilt and overall reach. Bar shape is secondary to me.
I found the flat bar to be awkward and annoying; I ended up switching back to my original round bar.
Also, the wing bar just looks sloppy.
I switched from round aluminum to carbon flat...I love the carbon, I noticed immediate difference in my hand comfort, but I've decided that I'll go back to round carbon...My hands are just not as comfortable on the flats..I think I'm more comfortable gripping around the bar closer to the stem rather than on the flats as it seems to put more weight on my wrists
Pound Solid
I switch last year from round to flat, what a difference. I used more of the bar as far as different hand locations than I did with the round.
1 - 20 of 29 Posts
