I'm just wrapping up my first build attempt and all in all it went pretty well. However, I am having some trouble getting the headset adjustment just right.
Note: this is a used carbon frameset (alum. steerer tube) and a used Cane Creek S2 headset. I did not install the headset as it came with the frameset. All I did was run the forks back through and put the top ring and cap on.
If I tighten up everything so that there is no play at all while holding brakes and pushing back and forth on the handlebars then it is too tight to turn smoothly. If I back it out enough to easily turn right and left smoothly then there is a bit of play. I can't seem to find an adjustment that has both no play and a smooth easy turning of the wheel.
Right now I have it adjusted to allow it to turn easily which means it has a bit too much play. (by my standards) I did pull off the very top ring and apply some grease yesterday to try and make it turn easier but that didn't help when tightened up all the way.
1. Is it possible the headset is just toast and needs to be replaced?
2. Am I risking any damage to the frame or forks by leaving a little play in the headset?
3. Am I just adjusting it the wrong way?
Any help would be appreciated.
