1 - 3 of 3 Posts
I have a threaded headset and was wondering if I would benefit more from a threadless one? Should I switch it out totally, bars and stem? I posted a similar question on a different board......Justin :D
Hs
If you spend enough money on a light all CF fork , light bar and stem, you can save weight.Otherwise a threaded HS does exactly the same job as a threadless.
Hi you will have to replace the fork, headset and stem, You may be able to keep the handlebar if the diameter is compatible with the stem.
1 - 3 of 3 Posts
