1 - 7 of 7 Posts
Mine came with a FSA headset. The forks (mine was a Wolf SL) now come cut to max length. If left to max length it allows 30mm of stack above the headset cap. Cervelo had problems with the Wolf steer tubes cracking if customers or bike shops left them too long when gluing the metal insert.
what do you want it to come with? most shops will switch a top cap to fit your needs. i've seen them at shops with +8 and +15 caps. The total stack ht. is top cap plus apprx 3cm for a total of approx 4cm. If you're over 4cm by a 1-5 mm it is fine.
1 - 7 of 7 Posts
