1 - 10 of 10 Posts
Hey, thanks for looking!
Im building up a bike. I am super pumped about it. It will be sweet. I have spent too much.
To continue with this trend of spending, I need some wheels!
heres a bit about my needs:
I am 185lbs after the off season, and about 7 lbs lighter when riding.
I am more of a sprinter, but I am going to be doing some triathlon
the majority of my riding is traditional roadie stuff, I will think about some crits and regular road races too. (so 30mm is likely the depth im thinking...)
I dont want these wheels to die easily, the roads here are brutal. REALLY BRUTAL!
I have a budget of $1500 but would like to spend less.
I am even considering significantly less if the wheels are good enough (Im not too much of a snob)
any suggestions on somthing that would fit the bill.
THanks for the help!
PS anyone try both williams wheels and ROl wheels with a direct comparison? WIlliams has ceramic bearings, rol is a little lighter for the same weight limit. Whaddaya think?!
So many Choices
I was just in the same perticament that you are; spend a lot of money on bike and components and had about $1,300 for a wheelset.
I live in the NW and some times my road bike needs to be more of a cyclecross.
I had a pair of Neauvations R28 for 4 years as training wheels. good wheels for training and a good price but not a race wheel.
I had a pair of DT Swiss 1420's where good but wanted something more aero.
I Tried a pair of American Classics 420's; felt stiff on the straights but not that great sprinting or cornering.
So I read the reviews here and then called to Sean at ROL; everything written about his customer service is right on. He will explain options and build you a wheel set you can train on and race.
I got his Race SL with DT Swiss 24/28 spokes. They are made for us 185 lb guys and are the most responsive wheel I have ever ridden bar none.
Price is less than Mavics of comprable build and we all know how bad Mavic's Customer service is.
Rolf Vigor RS, at 1590g there may be lighter wheels but the RS will take a lot of abuse and at 34MM they are pretty aero. You should be able to get a new set for $900 or less.
You could buy two sets for that money.
Say Niobium 24mm (XR-240) 32h with DT Swiss 340 for regular use, and Niobium 30mm (XR-300) with DT Swiss 240s for the race days and when you want to ride the aero set.
Nb30 / 240s 24/28 would be perfect for you. fast, light(ish) and tough.
i have run a 20/24 set for ~5k miles and never touched them (at almost the same weight as you, but on better roads). the 240s hubs are spectacular, and the 30mm rims are plenty stiff even with a low spoke count.
Discussion Starter · #9 ·
I know that there a lot of options out there, I appreciate the help. Im sure that there are lots Id be happy with, I just dont want to end up getting ones that look flash, but are lemons in the end...
Cpark
+1
This is exact set up I have and I'm about 185lbs.
With CX-Ray spokes, it came in at 1465 grams without skewers/rim tape.
1 - 10 of 10 Posts
