1 - 13 of 13 Posts
Bald Bastard
Discussion Starter #1
Can anyone help me date this Merckx? Also looking for model Thanks Steve
paramountz said:
Help date this Merckx
No problem. I'll pick her up Saturday, say - 8am okay? - and I'll show her a grand time. I'll even bring along my own saddle and seatpost for when I ride her, because you never can be too safe.
Grrrrrrrr,
2F2F
frame mid/late 80's w/ early/ mid 90's mix components.
you need rear dropout adjusters, the axle should be just ahead of the r derailer pivot per campy for best shifting.
just one pepsi and she wouldn't give me one
p.s. i went to your institutional learning facilities,
and i saw the tendencies' show palo alto '85ish.
Those are older (80s) chorus. The bike is a repaint. The flat top fork crown should be some kind of clue as to model.
Bald Bastard
Discussion Starter #6
St
I saw Suicidal quite a few times in the 80's - 90's. As for the bike most people think late 80's with a early 90's campy mix. I do not believe this bike to have been repainted if you look closer at the close up pics you cvan see it need some TLC.
I worked for a few Merckx dealers in the 80s-90s, and never saw those colors. The fade looks a little suspicious too. I'm sure there is a Merckx expert out there who could tell you for sure.
I'm not on drugs, I was just thinking.
On your left!
I thought the same thing...
when I saw the pic the other day.
I am no expert, but have been a fan since early 80's
Bald Bastard
Discussion Starter #10
why bobj why?
I was looking at the paint closer and look what I found? Can this be fixed? I had a feeling this was to good to be true.
Resident Curmudgeon
It doesn't look displaced, so it probably could be repaired by a competent frame builder. Natch, that would mean a repaint, etc.
Beetpull DeLite
I've had a similar spot in the rear seat tube cluster welded back together - no big deal. Such are the advantages to steel frames.
Call around to some of the local welding places and just ask.
surely having the lug re-brazed would be preferable. Just pray that the seatstay caps are brass-brazed and the seatstay/ST lug is silver brazed (so that the joint comes apart at a lower temperature, while the cap stays on). It's the sort of job a competent framebuilder would just love to do.
oh, and I think this is my first post in this forum - hi !
- Joel
1 - 13 of 13 Posts
