Actual tubeless tires are even tougher to mount on these wheels than clinchers. There's a couple of videos on youtube that make it look easy, but the sidewalls of the Hutchinson Road Tubeless models are so stiff, that I found it was easier with a wishbone style tire lever. The French tool company VAR make one (product #425) and it definitely helps with pulling the last few inches of bead over the rim, with a vertical pull which will not rip any rubber (unlike 'slicing' the tire on by digging between the rim and the bead to install it).
The VAR #425 should also be useful for other stiff tire/rim combos.
You can find this tool at Spa Cycles in the UK, they will do online orders.
