OK. I have spent 2 weeks chasing a clicking gremlin. In the past two weeks I have:
- pulled and regreased the crankset. Allso took the chainrings apart and greased the binding bolts.
- pulled and regreased my speedplay pedals
- lubed my cleats
- pulled and cleaned my seatpost (but didn't regrease as Seven's have a composite sleve. I also cleaned and regreased the binding collar.
- changed my chain, then stopped using my Wipperman link and used the Campy permalink. I also soaked the thing in home brew.
- pulled my saddle and greased the bolts on my Thomson post.
- Changed my wheels
- did a visual inspection for cracks on the frame. Found none.
The only thing I didn't do was pull the bars (although that may be next). I also should note that I purchased a use Campy Chorus rear derailleur, but other than I could hear the Wipperman link click this would not seem to be the cause.
What I have is a clicking sound that times with the crank on both sides at the top of the stroke.
What am I missing? I just got back from a ride and pulled the crankset apart again. I put my old non-MegaExo crankset and BB back on just to test it. That didn't seem to be the issue.
Campy fans...help me before I put my Shimano stuff back on!
- lubed my cleats
- Changed my wheels
