1 - 3 of 3 Posts
I have an older Kestrel and the front derailleur cable/housing is routed in the frame on the downtube. The housing comes out near the bottom bracket and then the cable (only) goes back into a hole inside the frame that wraps around the bottom bracket. My problem is that this internal routing is clogged/seized up. I've tried poking wire through it and spraying wd40. Anyone have any suggestions?
Discussion Starter · #2 ·
Good idea. The bike has been sitting w/ out a cable in the hole for a few years so I suspect its too clogged up for a compressor....unless there is a needle size attachment I can use.
1 - 3 of 3 Posts
