Well, I have this new frame. The only problem is that the driveside crankarm (and only driveside) rubs the chainstay. I've tried with both Shimano and FSA external BB compact cranksets and the problem can be fixed with a 3mm spacer. While the non-drive side crankarm will tighten down, I'd feel safer if the axle were a little longer. Of course I could fix the problem with a MTB crankset, but I don't want to have to buy a new crank and then rings. So my questions are thus:
1. What compact crankset has the longest axle (assuming cups are the same)?
2. Which compact has the largest Q-Factor?
3. Can I put a 50-34 on a 104BCD and where would I get the rings?
4. What can I do besides returning the frame?
Thanks
Thanks
