Hi
Just building up my tarmac s-works sl4 with the OSBB. Rotor states that all you need to fit the 3d+ crankset is the two 11.5mm spacers (one either side) and one 0.5mm nylon washer (non drive side. It states that you do not need the two 1.6mm bearing seals that would normally sit against the bearing face.
I've installed as per Rotor spec and there is approx 4-5mm space left which the non drive side adjuster cannot take up. I'm convinced that the bearing seasl should be installed as well, with these Im certain all will be well. Thing is I don't have any of the seals as they don't come with specializes's osbb so will need to order some
Anyone got an sl4 running the rotor 3d+?
Can you look at your configuration and let me know what you have fitted
Cheers
Lee
Cheers
Lee
