1 - 4 of 4 Posts
this morning my cane creek volos rear wheel has developed a slight lateral wobble. I've tried a different skewer. That wasn't it. When you look down at the wheel and push laterally one the wheel, it looks like the cassette stays put but the wheel itself wobbles slightly. I've checked to make sure the cassette lock ring is tight, it is. Is the problem a loose free hub body? The wheel is campy compatible. Thanks.
I just took apart the hub, cleaned and greased, and reassembled. It seems that to get rid of the play in the hub body, I have to load the axle so much that the wheel does not spin freely. Any ideas? Thanks
1 - 4 of 4 Posts
