1 - 5 of 5 Posts
Rookie question here.... I bought a frame recently and it uses the Campy Hiddenset standard. My question is whether I can buy any fork to use with the frame. Do Hiddenset headsets require special forks?
The one thing you will need is to get the "crown race" off of the old fork and put it on the new one. The crown race is specific to the headset, in this case Campy Hiddenset. This can be done without damaging it, but it can be tricky. Alternatively, you can usually find a crown race for the Campy Hiddenset for about $15 US if you look around (I think an LBS, if they had it, would sell it for >$30).
As for the fork itself, someone already mentioned the crown diameter. The other things you should look at is trying to match the rake and the crown/axle length. But that's not a matter of fitting the headset, that is a matter of keeping the bike's geometry and handling consistant.
Dave Hickey said:
Any fork will work but forks with a wider crown look better than a narrow crowned fork....The head tube is a larger diameter to accomodate the headset...Most of the carbon forks sold today have the wider crown
Don't different inernal headset manufacturers differ also in the outside diameter of the headtube? So, a fork designed with a wide crown to match a Campy Hiddenset Head tube would not match up well with a non-Campy Hiddenset head tube. I may be wrong there. Do you know if that is the case that there are different ODs on the head tubes?
1 - 5 of 5 Posts
