1 - 7 of 7 Posts
25.806975801127
Look at the end. Shift housing has a bunch of wires arranged in a circle, perpendicular to the housing length. Brake housing has a spiral-wound wire running the length of the housing. From the end, you'll see a starting point where the housing was last cut, and then a spiral going down the housing.
Thanks
One thing more. I cut the shifter cable with the park cable cutter. It crushed the inner wire.
Any advice?
Thanks
A nail or small screwdriver
I use a nail or a small phillips screwdriver to open up the crushed housing. In the future you could insert a piece of the old cable and cut the tubing and cable together. This minimizes the collapse.
1 - 7 of 7 Posts
