1 - 20 of 21 Posts
Read a couple threads with a ton of negative reviews on this forum as well as others. Some are dated back from '08. Has anything changed? Are RS10s still shiite?
They seem to come standard on many bikes including most of the mid range Cannondales. I'm 185 lbs.
Should I sell them as quickly as possible and get some ROLs? Or should I use em for bit, then upgrade, and keep em as spares?
I don't want to deal with broken spokes.
They come with quite a few bikes simply because the manufacturers can use them to keep the price of the bike down and most high end bikes will have the owner replace the stock wheels with their own.
It depends on what you want to do really, I sold them and replaced them with RS80's and I'm happy as a clam. About 8,000km on them and only had to be trued once (due to a crash that I miraculously walked away perfectly fine)
I wouldn't worry about broken spokes (not saying it won't happen) on them any more than a lot of wheels. If you read between the lines of a lot of reviews that mention that the people writing the reviews aren't really to be taken seriously. Statements along the lines of "I might have hit something" kind of give it a way.
However, they do kind of suck. But you own them and the resale value won't be much so you may as well see what you think for yourself. They aren't so bad that it's a safety concern IMO. Mine just went untrue at a drop of a hat and didn't roll that smooth.
· Cycling induced anoesis
FWIW I go about 140 lbs. most days, put 6,500 miles on my RS-10's and had them trued once. They won't win any awards for refinement or light weight, but as a recreational/ training wheel they're fine, IMO/E.
As one poster stated, save for something better, but no real need to rush.
At your weight, you're probably on the edge of the point where you'd be flexing the wheels and/or popping spokes, so I'd recommend either riding them into the ground if you want to go that route, or selling them before you any miles on the as new take-offs. This is what I did when I got my Cannondale. I think I got $200 or so for the wheels and tires.
· Banned
i did some research on these wheels since i was interested in a CD also. They seem to be 50/50 good/bad experiences. Thats a bad percentage for a wheelset. If you already own them, ride them out and start to save money for a new set. if you dont have them, see if you can sell them as new once u get the bike or see if your lbs can give you a discount on the bike and let them keep the wheels.
I had you pegged as a big guy. With your brains you must have a giant head(in proportion).
Here, I found your pic online....
Satisfaction with these wheels might run inverse to the rider's weight. I am 130 pounds and have 1500-2000 on my set and they still run true and spin well. On group rides, even though I am lighter than most, I can still keep up coasting down most descents (lots of times even have to sit up to windbrake), so they must be rolling pretty nicely for me.
I'm 160-165 and I've ridden mine problem free for around 2500-3000kms.
I had them trued once as part of a tune-up but it wasn't anything I couldn't ride with.
I hit a pothole once that actually put a gouge in my braking surface and the wheel stayed true despite a flat. It chews up brake pads a little faster on the right side now though....
I have nothing to compare them to, but I have no complaints either.
Discussion Starter · #13 ·
I just noticed that these wheels are only $140 a pair from Chain Reaction, didn't realize they were THAT cheap. I guess I'll just ride them and keep em as spares when I get a new set.
I'm now drooling over the DuraAce CL carbons for $650 shipped.
· Banned
^^ where did you see that price?
200 pounds and 1600 hard miles. Have hit potholes, elevation changes due to road work at 25mph, indentations for grating at 30mph (!), etc.
Took them to an advanced mechanic class last weekend and both were slightly not true. Took all of 5 minutes per wheel to get them back to perfect.
Have also had a loose (not broken) spoke too.
But again, I'm a big dude and ride really hard. I intend to ride these until they are dangerous or don't function fully and THEN upgrade.
I'm the weak link in the human/bike/wheel equation right now. When the wheel becomes the weak link I'll change it.
· Le Misérable
They came stock on the Cannondale I bought last summer to be my US bike. I read the same crap and was worried too, but they've turned out to be durable enough. They're a little heavier than average, but for what they cost they're completely serviceable. There are wheelsets out there that are just plain dangerous out of the box, but these aren't one of them. RIde on, and then enjoy the step up when you can get something better.
1 - 20 of 21 Posts
