Dmayner said:
PJ352,
First thanks for all your time and thoughts. You have been very helpful. Second, based on all the info I have provide do you think I have the right size frame? What would you say is the ideal KOPS and stem to bar length? What are the pros and cons in the KOPS? Should I be considering any adjustments?
Without knowing how you're proportioned or seeing you on your bike, it's difficult to say if you've been correctly sized. Given the fairly slack STA it seems odd that you're 6-7 cm's ahead of pedal spindle
along with running a 90mm stem. That would normally be a sign that without making those adjustments reach would be excessive for you, indicating the frame may be too large, but you mentioned that you've been fitted and are relatively comfortable on your bike.
As far as the ideal KOPS and stem length, there are some generally held beliefs, but no hard and fast rules. And really, what a good fit comes down to is little more than a rider feeling like his/ her position feels right, the bike is handling predictably and they're performing as they would expect - and in relative comfort.
I'm not sure what you mean by pros and cons of KOPS, but generally speaking moving forward of KOPS will predominantly use quad muscles which theoretically helps sprinters, while adjusting rearward uses hamstrings. Going too far back can make a rider over reach through part of the pedal stroke and (in turn) stretch the IT band - a common injury in cyclists.
Another aspect of KOPS (or fore/ aft saddle position) is that adjusting it forward or back shifts a riders weight forward or back
slightly. So (as an example) if you were complaining of hand pain/ numbness, I'd suggest moving the saddle rearward a few mm's. IME many riders are set up with fore/ aft set too far forward, causing incorrect f/r weight distribution.
Your call on making any adjustments. If anything, I would suggest checking that your saddle is level, because if it's tilted front down you'll find yourself pushing back to maintain a proper position and this can lead to fit issues. If you decide to reset KOPS, I would suggest rechecking your current position to ensure you know the correct starting point.
