Looking to build a strong training wheel set. thinking of kinlin 23mm rims and hope pro 3 hubs. i am 80kg, 6ft. i am thinking 24/28, 28/28 or 28/32. Will 32 be overkill? I like to lace them 2x both sides. Aim is to keep it 1500 - 1600grams.
This is exactly what I am thinking. There must be a limit of stiffness at some point where an average Joe like me cannot feel any more stiffness or beyond.I would say go 24/28. If the wheelset is stress relieved and tensioned properly, that spoke count would be just fine for you.
Keep in mind there will be no noticeable difference between a 24/28 and 32/32.
If you bring a spoke wrench along (which is a good idea in any case... ie denting a rim or whatever), then in the very rare event that a spoke breaks you will be able to get home, no problem.I like to build training wheels with 28F/32R for someone your size, so that when a spoke eventually breaks, you can ride home rather than walk or call for a ride.
24f and 28r is plenty. I wished they made a 16h so I could do 16f and 20r... and I weigh the same as you. Use Sapim Race on the DS. Mark the spokes for windup.I originally thought 32/32 will be my choice since it's a win win. I plan on lacing 2x front and 3x drive side and 2x non drive side rear. alloy 12mm nipples with sapim laser spokes. By the way, im targeting the Kinlin 23mm rims. If the lacing and wheel building is proper and the 24/28 will provide a sufficient amount of stiffness, than this will be good.
Curious... which spokes came loose?I currently ride 2012 FC 404 tubulars, damn they flex and went out of true twice already, ridden it under 1000 miles, 16/20... many are radial laced.
I'd advise using Race on the DS. You'll have trouble getting sufficient tension with Lasers.This is what I want: 24/28, Sapim laser spokes 2x front 2xND/3xDS Hope pro 3 hubs with kinlin 23mm rims.
I was even thinking Sapim race spokes 3x DS and Sapim laser spokes 2x ND. Is this unnecessary?
Thanks a lot, actually I will have a builder build the wheel. ThanksAbout lacing patterns: White Mountain Wheels - Handbuilt Custom Bicycle Wheels - Made in Alto, NM
Front wheels don't need to transfer torque, which is why radial lacing is ok. Cross lacing does not improve stiffness.
CX-Rays are not stiffer than Lasers. Lasers should be fine on the front wheel. 100kg there is plenty. But if you can afford CX-Rays, they are aero, and it's easier to prevent wind-up.
The lacing pattern is not that big of a deal... just don't do something stupid. The important parts of the build will be stress relieving and even tension.
Thanks for your reply, I can still decide on the spokes and nipples. I will purchase those from the builder (LBS). I had second thoughts about mixing bladed cx-rays with the rear rounded Race spokes so I decided to go round spokes all around and go with Lasers. Now that I ended up with 28/32 due to the nonavailability of 24h front Pro 3 hub. I'm confident that stiffness wont be lacking. I may even go 2xND/3xDS with the 32h rear hub.There will be no real world difference between Cxrays and Lasers. The one big advantage of the Cxrays is windup. I know your not going to build these wheels, but if you were the Cxrays would be easy to monitor windup with, and prevent for that matter. Where as Lasers and Races are going to wind up no matter what, making the incorporation of windup into the tensioning process absolutely pivotal.
While I don't disagree that carrying a spoke wrench is a good idea. If the idea is to to save on weight (less spokes), what is the gain if you carry a decent spoke wrench? Not to mention some folks struggle with just cleaning a bike, let alone truing a wheel on the side of the road.If you bring a spoke wrench along (which is a good idea in any case... ie denting a rim or whatever), then in the very rare event that a spoke breaks you will be able to get home, no problem.
We should mention the benefit of cross lacing patterns.Front wheels don't need to transfer torque, which is why radial lacing is ok. Cross lacing does not improve stiffness.
